I am looking for the specifications for my now quite old Audio Technica AT-F5/OCC moving coil cartridge, especially what is the power output in millivolts it produces?
I hope you can help
I hope you can help
I used to have a AT-F5 and have been looking for the info,
I thought I had it somewhere but I can't find it.
However I'm pretty sure Werner is spot on.
the AT-F5 I'm sure is standard medium output, that is -20dB,
or in other words it needs gain of x10 to match MM output.
Most MM have an output of 3mV to 5mV for 5cm/sec.
I'd put the AT-F5 in exactly the same region as Werner.
🙂 /sreten.
(p.s. power output in mW's depends on loading)
🙂 /sreten.
