Audio Technica 33 PTG
Joined 2006
Hi
I am planning to use an Audio Technica 33PTG cartridge and would apreciate information regarding it´s best loading in ohm.
A good friend of mine suggested 180 - 220r so that will be my first attempt but as this is a critical build, I would like some more opinions.
Ricardo
I have been informed the AT 33PTG is happy with 30~40 ohms.
Any comments ?
I am searching the net and I believe the EAR phono preamp 834P uses a step up TX that loads the MC cart with 50 ohms.... am I getting closer ?
Ricardo
Becarefor Ricardo, step-up impedance isn't the same that a load resistor. Vinylengine suggest a minimum load resistor of 20 ohms or more
The coil resistance is 17Ω, so the load impedance is 94x the coil resistance. Any value greater than 10x is usually OK.
The series combination of coil inductance and load resistance will have a -3dB point at R/(2πL)
For example if you choose 170 ohms / 2π x 0.070uH (coil inductance) = -3dB at 386Hz
Mine advice is try to left out the -3dB of the ear bandwith in this case is more easy to do with lower resistance possible so:
20 ohms / 2π x 0.070uH (coil inductance) = -3dB at 45Hz not bad far away from mids-lows it's a good choice
That's always theoretically of course fine adjust by ear.
Sorry bad calculated, I trust in Audio Technica web so 70uH = 0.00007H
100 ohms / 2π x 0.00007H = -3dB at 227.355Hz very good out of ear bandwith
If was milihenry like Audiocubes web 70mH = 0.07H
100 ohms / 2π x 0.07H = -3dB at 227Hz very bad mid-low range bandwith
I doubt Audiocubes specs, seems the coil inductance very high for a small magnet wire....
