http://s53.photobucket.com/albums/g73/porporpor/
V -- I uploaded the schematics to PhotoBucket, they are slightly smaller due to the website constraints, but I think they will be large enough. Click on the image for a full size view.
This has to work. I have no idea why the email has not.
caliban said:http://s53.photobucket.com/albums/g73/porporpor/
Thanks again for your effort, Caliban! I got it know
Valde
Nope, I've bought it but built from the schematic.Hi Brett,
Ive thought about building allen wrights pre, need to buy the book first dont you? Ive read a few good things about his rtp3c.
Wrong, why? They work well, sound better than caps and give galanic isolation. Sure they can be a bit exxy, but so can caps and the RTP3 linestage is a difficult and potentially expensive build with 5 envelopes/channel. I preferred a similar line stage to what I suggested above to the RTP. Allen will no doubt disagree, but I've built both.It seems wrong to use transformers in a preamp, surely you can do as well if not better without this added expense?
Trying not to drag up such an old thread but I was looking in the schematics, specifically in the power-supply section in regards to voltage change.
Is there dual taps for both 50 and 60Hz voltage frequencies? What about going from a 110volt country to a 220volt. I have my SP-9 maybe being sent here to me here in Germany from Canada and wonder if this will work, or a step down transformer may.
thx
Shamus
thx
Shamus
