Hi, I have a research sp16 audio preamplifier and the microprossover has broken: MC68HC705J1ACP, someone could help me get it
If this is true, you would need to replace it and the programming inside it. This would have to be done by the factory, if they are willing and able to do so.
Indeed, this could be a problem if it is really dead. It's an obsolete part and you will either need someone else's SP16 to suck the code from or get AR to do it. Have you checked the supply voltage on pins 9 and 10? If that's fine is it driving the crystal ok. Testing on pins 1+2 with a scope. Use the probe set to 10X as 1X could drag down the crystal and make it stop oscillating, ground clip to logic ground.
Cheers
Matt
Cheers
Matt
You may also want to confirm a solid reset pulse. If you don't have a digital or storage scope, you can set up any 2-channel scope in X-Y mode, one channel on the CPU supply pin, the other on the Reset pin. If it's working right you'll get a momentary, nice square trace; you may have to keep your hand on the brightness knob to see it without burning at the stationary spot.
If everything is good up to this point, it's time to confirm that there are scan pulses everywhere they're supposed to be -- and none where they aren't (supposed to be). A static-damaged diode in the front panel has been known to hang up a CPU or two.
If it's still all good and AR isn't helpful, you might try looking for a 'dead' one at a good price.
Cheers
Cheers
it could be replaced by a modern microcontroller doing the same thing.it only controlls the volume and the input selections...find a programmer to do that for you.
audio research sp16
Hello, in principle the mute does not work for me and when I turn it on on the strip most of the LEDs turn on and when I turn to the mute it blocks and almost all the LEDs stay on.
I already contacted the factory directly and they do not sell me the chip, please I need help I do not want to lose this preamplifier.
i'd check the 5v, 12v . 12.7v and 13v supply rails, then change
U9: lx7001
u10 : 74hc595
Q7: 2n4401
resolder x1 4mhz
check PTH1
U9: lx7001
u10 : 74hc595
Q7: 2n4401
resolder x1 4mhz
check PTH1
You can get the part.
Audio Research does not sell service parts directly to consumers because too many are not qualified to service products. You may be qualified, but they do not know that.
You can get the part through a dealer or distributor, who can order it for you. ARC will program the micro, they need to know whether it is for an SP16 (with phono) or SP16L (line stage only).
Are you in the US?
Are you in the US?
audio research sp16
I am in Spain and the preamplifier is sp16 with phono I would appreciate it if you could help me
if you do all the measurements and checks we'll assist you.
first download the service manual and see the ic's and transistor i mentiones, where to measure the voltages if you have any electrical measurements skills:
AUDIO-RESEARCH SP16 SP16L PREAMPLIFIER Service Manual download, schematics, eeprom, repair info for electronics experts
Miguel, Audio Research has that microprocessor board in stock so you should the distributor in Spain, Sarté Audio: sarte audio | Soluciones Audiovisuales Integrales Tell Sarté what you need and they can get the parts/board for you.
Yes, just replace that board, it will be a lot less trouble, and probably cheaper that way also,
since the labor cost will be minimal.
It gets worse, it does not turn on the mute and when I raise the volume it locks and the majority of the LEDs turn on
I see 4 easy steps
1. Get someone who actually knows what they're doing to confirm that micro is really dead. Usually it is the clock or something stuck to one of the ports that causes the malfunction. But of course it may be the micro
2. Approach official dealer
3. The functions of the micro in that pre are quite simple. An alternative controller or even an Arduino will work. A few hours or at worst a day of programming/installation.
4. Sell it to someone who will enjoy getting it back to life. It is surprising how high are people willing to bid for similar broken junk.
I keep trying to repair the research sp16 audio preamplifier they have sent me the micro-threading and the problem continues.
Now the mute Led but when it started to raise the volume it was included I bought several 74HC595AN ic and it crashes when the volume is turned up and the majority of the LEDs come on and I have to remove the power socket. I don't know what it can be? ? ????
In his other thread I learned he does not even own a scope so we
will have a hard time teaching him to repair a "high end" preamp.
Miguel is in Spain so he should contact the technical services department of Audio Research's Spanish distributor: Soporte Tecnico | sarte audio
This will be the simplest way to get the SP16 repaired.
- Tubes / Valves
- Audio research sp16
