Audio note kit l3 phono
Hello everyone, I bought some pcb to build a phono of audio note kit, I assembled everything tested and it is here with me that it sounds great, I have only a small problem, at the volume setting of my pre I hear a hum, which goes increasing with the volume, I used shielded cables, and separate transformer for the filaments.I use a gyrator instead of the inductor. I am attaching the schematic so that I can comment better.
If your scope input is rated for at least 500VDC, just set it to AC Volts.
Set the scope input to AC Volts and 1V/division to start.
If the scope is not rated for 500VDC, make a x100 attenuator with resistors connected to the supply:
B+ to 1M to 10k to ground, and measure the 10k voltage. Set the scope to AC Volts, 1V/division to start.
Set the scope input to AC volts only (not DC volts), and adjust the horizontal line to the vertical center
of the screen. Then connect the probe to the circuit. The probe ground must be connected to the circuit ground,
or you will only see a large 60Hz sine wave.
After some break for work I went back to work on this phono, I read from who built this phono that it is silent and you can't hear anything from the speakers, so it's a matter of principle and I would like to be able to locate the problem, I connected the power output to the oscilloscope with a 100x probe, the ground is connected to the frame, and here's what I see, the oscilloscope is so set up, volts / div = 0.1V, time / div = 5mS, it could be useful in the intercept the problem?
Is the phonostage objectionaby noisy in. Operation?
Every builder, home commercial or otherwise claims their phono stage is silent. Haven't found that to be the case yet in 20 years messing with phono stages. They are never silent, cant be.
If you can get it to idle as quiet as a commercial unit, you are doing pretty good.
Someone who says they have a silent phono stage, is like someone saying they've never piked their nose.
Sounds great, but it isnt true.
