Not really I'm afraid.
Firstly I should point out that the frugel horns are not dipoles. They are back loaded horns, that (like a reasonable proportion of back loaded horns) have a rear-firing terminus and are designed for boundary loading. That is very different from a dipole. Unfortunately, there is also no frugel horn enclosure that the AN will work in. I know, because I designed them.
Expanding a little, being a relatively high Q unit, the AN model in question here is not very well suited to horn loading. You can, in the same way that every driver can be to a point, but it's a question of practicality & utility. The mass corner frequency, which is the practical upper 'limit' for enclosure loading is 137.4Hz for this unit; that's quite low & doesn't need a back horn. Due to the relatively high Q & moderate Fs, Vas, it already wants a large box for a reasonable 'standard' vented alignment and a horn would even larger (impractically large in most cases).
The simple Klipsch Rebel corner horn was designed for this and similar spec'd drivers: retro vintage modern hi-fi: Rebel
GM
GM
Joined 2009
I'm quite a fan of the BVR - at least I liked all your designs based on the novelty of approach although I didn't hear any of them. My Martello desktop speaker has a little bit of BVR going on, call it a SVR ... it was based on something from Henkjan I think. So a BVR for this AN could be interesting. Perhaps an MLTL loaded by a big-vent would allow somebody to claim all the features at once !
