• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Audio Isolation Feet
A&B SYSTEMS 01 aviation Aluminum (chrome plated) Isolation feet
A&B 01 is good for CD Player,DAC, Pre Amp to used.
This design can effectively solve the problem of uneven chassis,
Top and base is use one point combine,that can abate vibration returning.
Greatly improve the sound stage and imaging,
Specifications:
Made from 7075 aviation grade Aluminum with electroplated chrome(Silver color).
The base plates height is 18mm ,diameter is 34mm.
The top plates height is 11mm ,diameter is 20mm.
Total height is 27mm.
Weight :1 set 140g
Max Loading: 12 kg / Equipment
Price:US$21 one set(set of 3)
A&B SYSTEMS 02 aviation Aluminum Steel Balls Isolation feet
The Steel -Ball Difference
The Steel-ball Technology is based on direct coupling for effective transfer of sound interfering resonance. Fast resonance transfer is provided by extreme hard high-tech Japan Steel balls. Combined with precision machined materials like stainless steel or aluminum the optimum balance between damping and deflection is achieved. The resulting vacuum effect draws off unwanted resonance directly where it evolves.
The clear advantage: no resonance build-up, no overdamping, no loss of deflection. The A Steel-Ball technology improves the sound wherever sound-impairing resonance restricts the musicality.
Specifications:
Made from aviation grade Aluminum (Black color).
The base plates height is 17mm ,diameter is 35mm.
The top plates height is 15mm ,diameter is 16mm.
6mm Japan steel balls.
Total height is 25mm.
Weight :1 set 83g
Highly recommended for CD Transport, CD player, DAC.
Price:US$23.8 one set(set of 3)
A&B SYSTEMS VI-01 Alloy (chrome-plated) Isolation feet
VI-01 is made from Injection Aluminium Alloy, this metal alloy is frequently used in speaker drivers (bracket). It is excellent for vibration isolation .
The surface in contact with equipment have circlar etching to allow horizontal expansion and to reduce the vibraion further
This setup gives a more detail to the sound ,offer more punch and well control on bass and smooth high frequencies .
There is significant improvement on sound stage and focus imaging.
Highly recommended for CD Transport, CD player, DAC,Amp and bookshelf speaker.
Specifications:
Made from Injection Aluminum Alloy .
Circlar etching.
height is 35mm ,diameter is 30mm.
Weight :1 set 172g
Max Loading: 15 kg / Equipment
Price:US$14.8 one set(set of 3)
A&B SYSTEMS W-01 Red Sandalwood Isolation Feet + Red Sandalwood Base Plates.
W-01 is made from Red Sandalwood , bottom with brass install.
The Red Sandalwood is very valuable and precious.
Greatly improve the sound ,very warm and natural.
A&B W-01 is good for CD Player,DAC, Pre Amp and amp to used.
Specifications:
Feet and base plates made from Red Sandalwwood.
Feet bottom with brass install.
The base plates height is 8mm ,diameter is 33mm.
The W-01 feet height is 28mm ,diameter is 32.5mm.
Total height is 36mm.
Weight :1 set 80g
Price:US$32 one set (One set include : W-01 feet 3pcs and base plates 3pcs)
Please Visit my eBay store.😉
items - Get great deals on Audio Plugs,Socket, Connectors, Speaker Screws Damper items on eBay Stores!
