Audio input caps. Which one?
That is because the cap at the bottom of the NFB loop is essentially a coupling cap so provided it is is big enough it has little AC voltage so can generate little distortion - and signal levels are low there anyway. Passive crossover networks are audio frequency filters run at significant AC voltage so cap properties show up, although they are still swamped by driver properties.
Indeed, and I am a believer in we are not drops in an ocean, rather a whole ocean in a drop. 🙂 I do not want to ignore micro distortions that add up. Especially if it s cheap fix.
