Audio-gd NFB-8 24/192 DAC with TCXO clock upgrade
I bought this DAC directly from Audio-gd in January 2011. It is in excellent condition. A great DAC, the best I've ever owned so far. Very revealing yet smooth sounding... You can listen to it for hours. It rivals DACs in the multi K price range.
The DAC is a balanced dual mono design using 2 high-end Wolfson WM8741 which can support up to 24Bit/192KHz through the AES/EBU, Coaxial (RCA and BNC) and optical inputs. The USB input support up to 96KHz/24bit. The main clock has been upgraded to a TCXO by Audio-gd.
Photos are from Audio-gd. The actual DAC for sale has the latest ACSS 3 pin mini XLR plugs.
Specs from Audio-gd:
RCA Output
S/N Ratio:>119db
Output Level:2.56V
Frequency Breadth:20-20KHz
XLR Output
S/N Ratio:>122db
Output Level:5.12V
ACSS Output
S/N Ratio:>127db
Output:2.0MA
Asking $895
Ground shipping in the US will be around $45.
If using Paypal, please add 3% to total.
RCA Output
S/N Ratio:>119db
Output Level:2.56V
XLR Output
S/N Ratio:>122db
Output Level:5.12V
ACSS Output
S/N Ratio:>127db
Output:2.0MA
Asking $895
Less than 6 hours left till the end of the eBay auction! Starting bid: $795!
PS: I've reduced audio DIY by 90% after I found Audio-gd... I mostly do cables and tweaks now.
Audio-gd NFB-8, 24/192 DAC with TCXO clock upgrade | eBay
