Audio capacitor supplier needed
Well there aren't any in stock at Newark.com that have this low a life rating. There are 30K6772 Illinois @ 3000 hours, 16M8257 chemicon @ 2000 hours, and 97M5312 Cornell Dub @3000 hours. All appear to be 10 mm spacing (leads) snap in cap. You can look up the dimensions. On newark.com click passive components, aluminum electrolytic, then the capacitance and voltage. Mouser.com is closer to california, Newark is in NC. I just bought some 100V 4700 uf chemicon's, they are about 1" in dia and 2" tall.
Sounds like the spec for a nichicon KG. available here --> Nichicon Capacitor Series KG
Note that most of the partsconnexion ones are type I and the diameter you gave is the type II diameter. Note that type two have higher ripple current capability.
Percy Audio also sells Nichicon KG's (though they are mostly type II or type III ie the higher quality ones). Prices are comparable to partsconnexion as well. Michael Percy Audio Ordering Information
Tony.
