im working on one of these i found the mje2955g and MJE3055T to have shorted. everything looks ok. i wanted to see what else should i should be replacing since this is a older amp?
Have you replaced shorted semiconductors?im working on one of these i found the mje2955g and MJE3055T to have shorted. everything looks ok. i wanted to see what else should i should be replacing since this is a older amp?
Amp works ok?
