Audio Amplifier protections
¡Hola!, trato de hacer una protección para los Tips, y los Parlantes, para mi amplificador de audio, pero no sé como realizarlo.
Las características:
Vcc: 45 - 0 - 45
RL: 8 ohms
Si podés ayudarme...
Acá está el circuito.
Hello, I am trying to make a protection for the Tips, and the speakers, for my audio amplifier, but i do not know how.
The characteristics:
Vcc: 45 - 0 - 45
RL: 8 ohms
If you can help me...
Here is the circuit.
If a problem happens in the amplifier; the Tips will be hottest, and it is dangerous for the Tips. So, how can I install a protection for it?
si ocurriese un problema en el amplificador; los tips comenzarán a calentar y podría llegar a dañarlos. Entoces, como hago para proteger a los tips; y evitar q se quemen?
I've seen lots of pro amps use this circuit (alost the same as yours but a bit modified
P.S look up uPC1237 IC, it can give you delay turn on to get rid of turn on/off thump , DC detection and load removal, and over-current load removal(via relay).
