I am looking into building my first set of speakers. I want to use a kit because the crossover and box design is already accomplished.
Has anyone had any experience with this system. It seems like a good design to me, but i am just getting into speaker building. also i was looking at the subwoofer that is recommended with this system. Would I be better off sticking with it or going with something like the Vance series from Partsexpress. I there are systems that better than this one let me know. All feedback will be appricated.
BD
BD
for the money, this is a great setup. sure, you can get setups with better components, but that's only half the battle. the setup was designed by Dr. D'Appolito, so it's a good bet that the rest of the system is designed extremely well. Vance Dickason's kit also seems quite good, though i haven't heard it.
still, you can get the parts for the entire setup except the sub for under $600 bucks, not counting cabinets. you really can't beat that.
i'd be inclined to use a different sub, though
Thanks for your replies,
I thought that the intial design seemed really good. The weak part in the design seemed to be the sub. I will definitely get a different sub from what the kit suggests. I have no problem with the fact that I have to make the cabinets. The plans should be enough for me.
I realize that there are problably better systems out there, but this system is in the right price range and i like the idea of building it myself!
I was looking at building a sub for about $300(driver and amp) and then picking an enclosure. Are there any recomendations??
BD
BD
I'd look into the adire drivers ( http://www.adireaudio.com ) if I were you. The Shiva is really well thought of around here. And when I'm done with my amp/pre-amp & rear speakers I'm going to go with the Tempest for a sub.
BD, I am building this kit right now (from scratch). I have already finished the mains and the surrounds, and I am working on the CC. I am not building the sub.
The mains sound really great. They have really excellent bass response for 6 1/2" drivers. The surrounds are noticably lacking in bass extension, but hey what do you expect for a small sealed box with a single 6.5"
? Regardless, all four of them sound excellent, and when combined with a capable sub then they will tear the house down
One of the best properties of the Audax drivers, IMHO, is their imaging. They have very a detailed sound, which makes them ideal for HT applications. I attended a DIY speaker competetion earlier this year in the Washington DC area, and I was ecstatic for one important reason. The tweeter that consistently sounded the best to me (and many others) was the TM025F1, and the AP1x0Z0 drivers were also repeated favorites with the crowd. Granted, I heard these drivers in other designs with many different cabinet styles, but they consistently provided great sound regardless of their enclosure.
Right now the only two things holding me back on my HT are my center channel, which is in progress, and the Outlaw 950 pre/pro. God only knows when they are going to actually ship that
, so I have some time to finish my CC
Please feel free to post or email if you have any questions about constructing the kit.
i second the vote for one of adire's subs. i just finished building a sealed tempest and will try to put it on my webpage this weekend. needless to say i'm very satisfied. it's hard to do much better without spending significantly more money.
if space for the sub is an issue, there are other options, but if you've got room, check out a shiva or tempest.
you can get a PE 250 watt amp and a tempest for about 300.
Space is not an issue neither is WAF.
I built myself a Home Theater room in my basement(the wife has no say in) which has a projector in it!! I am now getting to the audio upgrade, I like the looks of the Shiva's.
One thought i had was.
I have a crappy 12 passive sub from RatShack, i could replace the 12" sub in it with a Shiva and maybe cut out a place for a 250 sub amp. I could see how this sounds, if I Don't like the sound, build me a custom box. The sub enclosure is ported and it looks like a very standard enclosure. I bet there isn't even stuffing in it.
I cannot wait to get started on the Audax speakers. They will be replacing a mismosh of speakers.
I just need to get my audio to match with my 109" screen.
BD
BD
You'd be better off making an enclosure specifically for the shiva (or shivas) if that's the route you go. Just having the driver in a box doesn't make it sound good, needs a well made box with the right size/tuning frequency/dimentions if you go with ported (which your other box is).
The Adire drivers are very good indeed, but I've been hearing not-too-great things about the PE amps. Perhaps an Adire or Apex Jr. amp would be the better choice.
hmmm, what have you heard. i haven't actually bought the PE amp yet, so i'm wondering exactly what you had heard? i imagine the adire are better, but somewhat pricey. the apex is nifty, but i would think it's in the same league as the PE.
the next step up would be a prosound amp, crown, qsc or something like that.
Bryan et. all
I too am interested in any information on the PE 250W amp, and how it compares to the Adire products (e.g. the AVA250 or the HS200).
The HS units look nice but I am concerned that they have simple phase switches and not variable adjustment. How important is the phase adjustment? I am assuming it's largely dependent on the sub placement in the listening room and its distance from the main speakers?
Adire's marketing for the AVA250 seems to take a swipe clearly at the PE 250W amp: "eliminate that annoying excess boost (in some cases, as high as 6 dB at 30 Hz!). "
If designed properly what's the sin in using an amp with some boost?
thanks
<peter>
thanks
<peter>
Ok, this is just what I've heard.
As for the reliability of the PE amps, another fellow on the board with the alias BAM has been having severe overheating problems with his 120 watt sub. You can probably find the thread in the SS forum somewhere.
As far as that boost goes, it is not just PE amps that give this sort of boost. I think the PE amp is +3db, but other manufacturers do indeed have +6. As far as home theater goes, this may not be a problem, but if you have a well designed sub, a boost of this magnitude can become quite annoying, and make the bass overwhelming, and the SPL measurements will be far from linear without active EQ. Many people who buy the PE amps change the resistor values to disable the bass boost, but this voids the warranty.
And in my own experiences, I find that infinitely variable phase adjustment has been crucial for integrating my sub properly with the mains. In my room, the phase adjustment is about 70 degrees: a far cry from 0 degrees, or 180. I fiddled with the phase control a lot longer than the crossover control, and I found that I could clearly distinguish changes in the phase control to a greater extent than the crossover.
Although I have no direct experience using the PE amps, I can attest to build and sound quality of the AVA-250 as being superb. The heatsinks have rarely gotten more than warm to the touch, and the solder joints on the PCB seemed to be neat. The controls also feel sturdy, and the whole piece seems to be very well constructed.
I was considering building these speakers. The only thing is that I am more partial to floor standing towers for mains as oppossed to using speaker stands. I guess I could just leave the speakers as designed but make them tall enough to sit on the floor? And maybe stuff the cabinet or something to make sure it wouldn't resonate? What about doing something like adding a side firing woofer? Would this be feasible?
Dave
Dave
ogp : You can definitely modify the mains (and the surrounds) to be floor standing. I have seen a guy hanging out I think on HTF or Madisound (can't remember where I saw his pics) who did just what you describe. His web pics are here. Basically you can extend the four vertical faces of the cabinet to be tall enough to be floor standing. The important rule is to keep the "bottom" of the internal volume the proper distance from the top. This means that the upper part of your cabinet is the correct volume, and the lower part is empty, and does not affect the characteristics of the drivers. The lower part is also an excellent place to stash the crossover networks and the terminal plate. If I had to do mine over, I would have taken this approach.
mattpman : since you are building these speakers, I will assume you have already checked Audax's design pages
. These speakers are definitely bi-wirable; all you need to do is use a terminal plate that has four lugs instead of two. The crossover network for each driver is separate. Just hook up each network to a different pair of lugs inside the cabinet.
Some really kick *** pictures of the finished kits can be found at:
here
and the
center channel
and
here
here
and the
center channel
and
here
Thanks Silverpike, you've cleared that up for me (I thought they were, but had doubts)
Thanks again
Matt
ooh, ooh, forgot...are the holes (for the drivers) given on the audax website the cut-out holes, or the router holes (I want to fllush mount). Sorry about that quessie, I forgot to ask it in the first post.
Thanks again
Matt
mattpman : The cutouts shown on the cabinet diagrams are through-hole cutouts. You will need a rabbet bit (or some similar method) to route out a lip around the edges of the specified cutouts to flush mount the driver.
I highly reccomend looking at Audax's individual driver pages. They have detailed physical dimensions for each one. I actually routed the cutouts and rabbets before I ever had the drivers in my hands, because Audax has very accurate physical dimensions
. My drivers fit right in after I purchased them
Poke around Audax's site you can find the links to individual drivers.
- Audax Home Theater Kit
