Joined 2002
Im looking for a schematic to tell me the pinouts to turn on a atx powersupply and also to load it i remember reading on this form that you have to put a load on the 5v side to make the power supply put out its full curent.. ( some one was using one for a car amp and that is where i read it..
Can any one help me please..
Jason
Jason
Try this ...
http://www.pcpowerandcooling.com/support/index_docs.htm
This one mentions something about a load on the 5V buss:
http://www.pcpowerandcooling.com/support/installation/ulqt_pwrsup/silencer275_atx.html
I'm not sure, though, if you can take the spec for the load for a particular model, and assume it applies to a different model.
-- mirlo
-- mirlo
Joined 2002
Joined 2002
aaaahhh hem i need the schematic to tell me the pinouts what ones to short out to make it turn on not the device that tells me nothing.. i need to turn this thing on..
Not exactly sure as I don't have one in front of me.
But I think the green wire.. should be like 4th from the left on one of the sides.. short it with ground. With my supply it'll only work by shorting to a specific ground that is located very close to the green wire. don't remember which. just try all of them.
The link that I posted turns on the power supply.
All power supplies comes with a manual that shows the pin output of all the power connector. The power supplies that came with the case does not have a manual for the power supply.
JasonL, why are you going to power with computer power supplies. Its best to buy a linear power supply for audio use. Also 18 gauge or gage is not big enough for high current devices. There is too much a voltage drop for amplifiers.
- Digital Source
- Atx computer powersupply Wireing schematic
