Hi Tyimo, nice to see somebody else looking at those older impulse Horns. There was a little discussion about them here a few months back. The layout of them is unusual in that they do have a large filter chamber but it is the whole height of the enclosure, tapering from wide at the top, though not evenly, down to narrow at the bottem which becomes the throat. The horn is then directed up to the top, turns over and comes back down to the bottem like an upturned BIB but not as long. Probably a quarter wave. The mouth at the bottem, full width and deth of the enclosure almost, then appears to be 3 - 5 cm above the ground. Is this mass loading the horn? Does the layout of three folds full height in the box have some sort of resonating effect? The three folds are the filter chamber and the two horn folds. Seems to have been very impressive at its time.
Hi jamikl!
Could you tell me where??
Yes, very unusual. It's design method is contradict to every "classic" design rules!
I think I need to open a new thread for this questions.
Greets:
Tyimo
The layout of them is unusual ....
Greets:
Tyimo
Hi Tyimo,
to be sincerely, I have no plan if this horn works and why it should sound very good. Dont understand me wrong I belive you that they sound good. I have heared a lot things that shouldn`t work but they do and that very good too.
Here is my simulation with your parameters:
From my point of view the chamber is a bit too small.
scottmoose has given a good answere. It is a thing between a BL-Horn with a big chamber and a usual BR. I would call it a HornReflex.
Here you can see 5 different way how I simulateted one driver.
Black Line is a usual BR
Green Line is a BL-Horn with 1m lenght and a 3200cm² opening area.
Blue Line is a "regular" BL-Horn with a chamber of 3 ltr.
As you can see there is now real differece between a BL-Horn with a big chamber and a BR.
sorry for my late response
greets Till
greets Till
Hi Till!
Thanks for the simulations. I got the same with the MJK's Mathcad sheet.
Yes, I think this box is in the same category.
I have an idea about the heard good bass reproduction.
Philips used it in little "sub"bass-boxes: they tuned the box to strong 80Hz reproduction because they said the human ear and the brain will add to the missed lower frequencies. Forexample: We here in the reality strong 80Hz and the brain will imagine that also some 40Hz and even 20Hz was played!
Sorry for my bad english. I hope you can understand the basic "psicho-acoustic trick".
Greets:
Tyimo
Greets:
Tyimo
Hi Tyimo,
yes I know what you mean and that sounds realistic to me. Otherwise why do we like the bass in cars even when they dont play deeper that 60/70Hz?
greets Till
Hi Till!
Yes!🙂
Totaly another question:
What is your favorite amp? I know your favorite drivers already! 😀
Greets:
Tyimo
Yes!🙂
Greets:
Tyimo
Hi Tyimo,
right now I have got a single-ended-class A MosFet amp (similar to a Pass Aleph)
my new project is a 6-channel amp with the Aleph-X. I have 6 of the PCB's out of the diy-audio group buy.
I will use them for a full active system ( one amp for the tweeter, one for the midrange and one for the woofer).
greets Till
greets Till
Helmholtz resonance with horn shaped duct
Hi Till!
I would liket to ask you one more unanswered question:
How could be calculated the Helmholtz resonance with horn shaped duct in a BR box???????????
Greets:
Tyimo
Hi Till!
Greets:
Tyimo
Re: Helmholtz resonance with horn shaped duct
It can be modeled with Martin King's software. I have been working with Scottmoose on a family of BVRs and that is what he is using (BVR = Big Vent Reflex = Replikon-style box)
dave
Tyimo said:How could be calculated the Helmholtz resonance with horn shaped duct in a BR box???????????
dave
Hi Dave!
Thanks!
Yes I know and I did it already, but I would like to know is it possible to modify the original Helmholz resonance's equation fo this kind of duct shape????
Tyimo
Thanks!
Tyimo
dave
Hi Dave,
you are 100% right. I allways said that for me a BL-Horn is nothing else than a BassReflex. In my way of building BL-Horns I can shorten the horn and reduce the opening area without any bigger differences. Only the sound will change a bit. I personaly like BL-Horns (or name them BR with a big Port or HornReflex or how ever) more than a BR.
In this simulation you can see what I mean
the blue line is a "normal" BL-Horn
Tyimo said:Hi Dave!
Thanks!
Tyimo
Hi Tyimo,
I have no formula for that but if you make the hornmouth bigger you have to make the length and throat bigger too.
greets Till
Hi Till!
Yes, I know.
Thanks!
Greets:
Tyimo
Yes, I know.
Thanks!
Greets:
Tyimo
- Full Range
- Attention Raffi and Till (Roemhild)
