After two years of solid research and reading of the diyaudio.com pages, I’m finally ready to begin my own project. I’m probably only going to do this once, so I want to get it as good as I can. Reading up on speakers, I was taken by various attempts to “clone” commercial products, namely the Wilson Audio WATT/puppy combo; this speaker became my benchmark in performance and looks. As my drivers are totally different, any resemblance will be in looks (and hopefully performance) but what the heck!
I really like what Tony Gee does – he puts a lot of design into his projects – and so want to use the drivers and crossover of the “Tempo” (Seas tweeter, Vifa PL18WO mid) but in a closed box of ~15L for the top half. For the bottom half I want to use the Seas L22RN4X/P ported in a ~30L enclosure. This would be a 2.5-way loudspeaker (like some of Tony Gee's other projects) with a 1st order low-pass filter and zobel correction on the woofer. So far so good if you're only using one woofer, but here's where it gets interesting. I want to use two woofers. Is this possible?
I have no idea how to wire this. If I run the 2 L22’s in parallel, the sensitivity goes up way above that of the Tempo. If I run them in series then I now have a 16ohm load vs. the 8ohm of the uppers and who knows what will happen. So what do I do? I need the help of the diyaudio.com community because I really want to make this work. Thanks for any help in advance,
Philip
Philip
