Hi!
A friend of mine just asked me how he could hook up 4 - 5 Headphones to the Speaker-out of an amplifier (and the amplifer has no headphone connector).
Although I discouraged him, he really need s a quick and dirty solution for live recording on minimal budget, and the headphone connectors on the computer used for recording were too quiet for live recordings...
Any suggestions (since I am not at home, and cannot check the way some old amps I have connect their headphone connectors)...?
Thanks,
Arndt
Thanks,
Arndt
Connect each headphone via a 100 ohms (or slightly more) resistor. Be prepared though of noise from the amp.
Thanks for the answer...
Just one thing, is the rating (W) of the resistors important? In other words: Are normal 0.25 - 0.5 W resistors sufficient, or do I need 5W , 10W or more?
Bye,
Arndt
Bye,
Arndt
mrfeedback said:Typical 40W amplifiers run 220 ohms 1/2W resistors in series with the headphone outlets.
Eric.
Would that also be applicable if they run multiple headphones into the reistors?
Or do they take a resistor for each headphone, calculating the normal paralleled resistor value?
Bye,
Arndt
220 ohms per headphone channel = 44 ohms total load on the amp per channel.
IOW you need 10 220 ohm resistors to run 5 headphones.
Eric.
Eric.
I used to run a set of headphones directly off my Harman Kardon. No resistors. They were 600ohm headphones so I guess they wouldn't have been as sensitive as regular headphones; still, however, they didn't produce any noise whatsoever. I think if you find the right amplifier, you don't have to worry to much about noise. However, I suppose you could fry some headphones quite easily by not using the resistors 🙂...
- Attaching mult. headphones to amp speaker out
