attaching a headshell
Hi, is it possible to get a really good mechanical fit?
I think that this joint is critical to the sound so no glue is best.
What's your tonearm shaft made of? As acrylc expands a lot, I guess heating it in boiling water would be enough to get you a good interference shrink fit which would give a much better sound path than any glue.
regards. jeff
thanks Jeff!
The shaft is made out of wood so shrink fitting wouldn't work(at least I don't think it would). I think I'll just going to go with a screw, I have an experimental arm with an acrylic headshell attached with a screw that sounds better then having the cart attached to the bottom of the wood shaft. thanks for the help
Hi i am making a tonearm and my shaft will be a carbin graphite tube. I was planning on making the headshell out of aluminum, to fit inside of the tube. Would this method work for heating up the tube to make it fit over the Aluminum?
Does the no glue concept apply to the whole arm (eg pivot mount/counterweight mount)?
FortyTwo
