ATG 6500.1D (the other amp)
Pin 1:0.00
Pin 2:5.09
Pin 3:0.00
Pin 4:0.16
Pin 5:2.13
Pin 6:3.70
Pin 7:2.11
Pin 8:4.81
Pin 9:5.53
Pin 10:0.00
Pin 11:5.76
Pin 12:0.00
Pin 13:13.32
Pin 14:5.76
Pin 15:13.31
Pin 16:5.10
With pin 8 lifted the amp will power up but protection light is still on not the power light but amp produces both rail and regulated voltages
Do you still read a short between terminals 3 and 4 of the driver board?
Are you 100% sure that there isn't a hairline bridge between them?
In #24, you stated:
I noticed I have 55 ohms between gate and source on the output pads for the amp .
Is that still true?
Both high and low side?
I see the issue . When one of of outputs blew at some point of burnt the board and was hard to see and it made the board conductive .
I will fix this issue get a new 3525 since pin 8 was out of circuit and leg broke when I tried bending it back .
Is there a good replacement for the rectifiers?
They are mospec F20C20A and F20C20C
The legs got broken from taking them in and out of the board .
