Dr.H said:Thanks everyone,
I will try the following and report back:
Feeding 74hc74 with the cd players clock (synchronous reclock)
Reclocking with '74 AFTER 74HCT08
Jocko, any info on the SPDIF circuit you allueded to? Any diagrams perhaps?
Ryan
Try replacing the '74 with the twin '86 solution in post 16.
http://www.diyaudio.com/forums/show...2229&perpage=10&highlight=74HC86&pagenumber=2
Oh........really?
"Just to add, this DAC & reclocker together with Audiomeca Memphisto II transport produced truly amazing results. I don't think there's any "digital" combination / stand-alone player out there that approaches analog closer than this combination."
OK, bub.........next time you are in Texas, schlep that sucker with you. This I have to see versus my CD-80.
You will note that he said async reclocking on the TX end is not a good idea.
Jocko
Jocko
Thanks for all the responses. Several comments have been made about reclocking not being an optimal solution on the transport side, but should be implemented in the DAC.
I modded the Rotel 855 in order to improve its performance as a transport. The unit already has extensive power supply mods (5 transformers etc...) and I was hoping to find other methods of improvings its digital ouput since I use it as a transport. If I can make it sound like a PS Lambda/Theta/"your best transport" I 'll be happy.
So, if asynchronous reclocking of the SPDIF stream is NOT the way to improve the performance of the unit as a transport, what alternatives are there?
Thanks for ideas!
Ryan.
Thanks for ideas!
Ryan.
Dr.H said:Thanks for all the responses. Several comments have been made about reclocking not being an optimal solution on the transport side, but should be implemented in the DAC.
Thanks for ideas!
Ryan.
Synchronous reclocking, as shown in the thread linked to by Joseph K
Thanks for ideas!
Ryan.
Yoy may consider synchronous reclcking, as several are trying to suggest you for a while
your pre-occupation for async looks religuous to me, what is the religion ?
Re: Since you brought up the subject of religion........
Hahahaha, Yahooooooooooooooooooooooo!Jocko Homo said:
Religion?
What? Where? Who?
Synchronous will be attempted. FYI, I used the d1 to q1 to d2 to q2 scheme on the '74 and this removed the clicks and pops, so metastability it was after all.
Will let you religious people know the benefit of synchronous if any. Any proposed burnt offerings (and please id the deity)?
Still not addressing the question of sequence though (i.e. driver then reclock or reclock then driver (as I have it at the moment).
Thanks for the ideas.
Ryan
What? Where? Who?
Ryan
Re: Religion?
Hi Ryan,
I have a ready scheme that is adored in some circles for Asynchronous Reclocking. It seems to work well with the TDA1541 and the AD1865 but not so good with the TDA1543. (All NON-OS)
Don't ask my why, maybe Bob has the answer.
You can obtain the schematic of my ASR by sending me an email through the forum's system
Dr.H said:What? Where? Who?
Ryan
Hi Ryan,
- Digital Source
- Asyncronous reclocking of transport SPDIF output
