Hi all,
I'm currently fleshing out a design for a USB headphone DAC. I've recently been hacking around with the XMOS USB Audio 2.0 reference board, which interfaces quite nicely (natively) with the linux kernel and ALSA drivers.
The goal of this design is bit-perfect 24/192 audio via asynchronous USB, generated through a delta-sigma DAC, and output through a low-distortion headphone amp chip. My current chip chain is the following:
USB3318 PHY <-> XMOS XS1-L1 (-> SRC4192) -> WM8740 -> TPA6120
My question is this: with the XMOS handling asynchronous packet transfer, does the added jitter attenuation of the ASRC still outweigh its sonic alterations? In other words, is the ASRC even necessary anymore? The purist in me says I should kick it to the curb before this design goes any further, but I'll admit a lower experience level than many in this forum.
Thoughts?
Thanks,
~ Brad.
Thoughts?
Thanks,
~ Brad.
