Local pickup only in the Phoenix, Arizona area.
Denovo Audio MDF 4.0 cu. ft. Subwoofer Cabinet for 18” Subwoofer, excellent condition
https://www.parts-express.com/Denov...r-Dayton-Audio-18-Ultimax-300-7089?quantity=1
Unassembled MSRP: $248 (not including acoustic foam, mounting hardware, cabling or input connectors).
4.0 cubic feet • External dimensions: 23" H x 20" W x 20.75" D • Mounting depth (mounting baffle to brace): 11" • Subwoofer recess: 1/2" • Weight: 62 lbs.
Bolt locations at 440 mm = 17.32" (17.32" = 17 5/16") were installed for a B&C 18 TBX 100 driver, but should fit most common 8 bolt 18" woofer frames.
Included: acoustic foam, (8) machine bolt fastener kit installed, nickel plated binding posts and high quality driver cable.
$100
$100
