HI i've recently purchased an ASK WSX lcd panel of ebay. First day great fine picture everything working, my monitor picture has shodows though but lcd picture is fine. Day two and after some moving around the monitor and the lcd recieve no signal. tested averything and I sure its the cable that has failed. The only problem is that the ASK WSX has a 26pin VGA like port to connect to and thats it. I've never seen a 26pin connector before and can't find one anywhere. The cable that needs replacing went from a VGA and split into a VGA and this 26pin vgalike header. Can anyone point me in the right direction? I'm thinking that i may need to make a cable out of the parts but I have no idea on the 26pin wiring; but only as a last resort.
Thanks,
Nathaniel
Thanks,
Nathaniel
