A branch of the original company is still doing coffee and amplifiers on the other side of town. I see a 426 above the tea shelf.
https://www.armstrong-audio.com/
Interesting business plan: Pa fixes amps while Ma demonstrates the refurbs and maintains a flow of prospective clients. I like it!
I don't think any repairer worth his salt is going to work cheap or spend the vast amount of time needed to teach you how to avoid his services though. You'll need to learn the electronic theory and design, components and practices of manufacturers before you can confidently repair anything you're likely to come across relating to audio electronics. You're also best off reading a general electronic repair guide text first, to learn why repair is not a simple undertaking and how long it's going to take to be proficient at repairing commercial audio products, acquire and use the necessary test instruments, identify faults correctly and get the repair/replacement work done without making a mess of it.
For a quick illustration of how basic solid state faults can sometimes be tracked down with visual clues, this video about the repair of a very simple stereo amp. should help with seeing how difficult it might get unless, like the presenter, you already understood how they worked, the likely component types, values and functions and how they're all put together, which varies significantly and becomes confusing with the changes in electronics that have occurred over the 60 years solid state home audio has been around. Some old amplifiers were built like birds nests of loose wiring inside, recent models with impossibly tiny surface mounted components. Nothing is universal or always follows the same rules.
Thanks. Aware and sent them email last week. But no reply. Shall call them for an idea of costs...A branch of the original company is still doing coffee and amplifiers on the other side of town. I see a 426 above the tea shelf.
Indeed it's a tall order and worthy of satire. My initial communication was to a local neighbourhood group where I imagined possibly finding an amateur in his shed. No such luck. In this context is seems to be high-level amateur and retired professional, with many glad to share their expertise. In the slim chance someone is nearby I thought it.might go beyond online ping-pong. Thanks for the link, I obviously have to start with the groundwork rather than looking over the senior surgeon's shoulder...Interesting business plan: Pa fixes amps while Ma demonstrates the refurbs and maintains a flow of prospective clients. I like it!
