ARGH! One channel failed ... where to start?
It's an ESP chip amp and one channel has failed. It happened when I stood on some cables, I heard a little zap, the sound cut out from one channel. I've checked cables and they all seem fine. I also can't see how I could have caused any fault.
Now I'm a little stuck. I know how to identify the parts and follow plans, but not how to fix.
Can anyone suggest where to start, what to look for?
AX tech editor
Joined 2002
Do you have a multimeter? Can you check supply voltage, amp output (DC with no signal) voltages?
Jan Didden
