Them darn LEDs are everywhere! Was wondering around the house this morning at 3AM and noticed LEDs everywhere, some actually lighting my way.
- The bedside clock
- The cordless phone
- A riot of LEDs on the cable modem, router and VoIP device.
- Clock on the stove
- Clock on the microwave oven
- Water dispenser on the fridge
- Lighting inside the fridge when opened.
- Amplifier in living room
- Another telephone
- Faux votive candles my wife had left on
- Computer mouse
- Now the back light of my computer monitor
All glowing their little hearts out.
I've heard that they also make great voltage references and can even be used for biasing. Whoulda thought?
We have a separate 12V solar powered system at home. Rooms have two switches for lighting, one for normal AC mains powered lighting and the other for the 12V LED lighting.
in one room, I used a 30 LED strip with extruded aluminum case. In the other rooms, used a length of cheap flexible light strip (using those 5050 LEDs) with double sided adhesive.
After a while, the cheap LED strips deteriorated and dimmed to almost nothing after being used daily. The more expensive aluminum cased LED strip still works at full brightness.
These days, I pay extra for better quality LEDs and stay away from cheap ones if I know that they will be used regularly for a while. Bought 2000pcs of Osram long life PLCC LEDs and had boards made. Now I make my own LED strips so I'm sure they won't dim after a while.
LED Lighting
Take a look at the cost of what it would cost to make a equiv. sterilizer out of LED's, I'd did & I was amazed at the cost.
Guess what, took the UV ballast apart, bulk ecap (47uF/250V) exploded, 10 years old, not too bad. The sterilized runs 24/7/365, so 90Khrs MTBF. The UV lamp has 9Khr life, last one cost me $100.00.Speaking of lighting, my UV water sterilizer ballasts is beeping this morning, now I have to tear it apart and figure it out, damn,
I happened to glance a bulletin on the returns desk at Home Depot a while back -- it seems that some folks have been returning the Phillips LED spotlights but inserting a regular incandescent in the packaging -- about a $24 difference. Who knows what would happen if these folks turned their ingenuity into bona fide economic activity.
[*]Faux votive candles my wife had left on
Our candles are with timers. They switch off after 4 hours, and switch on the next day at exactly the same time. Very convenient.
It's certainly economic for them. 😛Who knows what would happen if these folks turned their ingenuity into bona fide economic activity.
Ha! I couldn't see those, as they are buried deep in the amp guts. Need to get them out where they show.I've heard that they also make great voltage references and can even be used for biasing. Whoulda thought?
I hope they don't turn off after 4 hours.
Reading a lamp spec, the lamp half life is the # that they are stating, it is a statistical method to fool the user. They ain't going to say in 50K hrs, half are not working!!
I don't agree. This kind of info is given to those who know what it means, i.e. the pro users, not us consumers.
Pro users will replace light sources on a group basis, before most of them have failed, as this is the most economical solution.
Average spent hours at failure rates of (e.g.) 5%, 20% and 50% are a basis in the decision on when to replace a group of lamps.
#181 Yes, LED's are very good references. They have wide use as the reference in a constant current source. Red LED's even have some thermal tracking advantages and I have been told green are more stable. To go off the deep end, look up Red Light District tube amp and you will see what a few hundred can do. I did see a DYI amp once that mounted the IPS CCS LEDs in the front panel as power indicators. I have never run that much current through them.
#187, 188 I am pretty sure, for an LED lamp half life is not MBTF.(mean time between failure) Just like a florescent bulb, It is the average time until the light emitted has degraded to some specific level. Florescent are spec to 80% I think.
dx.com has some nice LED strips that I've been meaning to try out, they also have some great WF-501B knockoffs, charging the required batteries can be a bit tricky/explosive though, haha.
TK Monster Explosion
As you say, buying quality is of the upmost importance to me too, same goes with rechargeable Li-ion batteries.
Shortly after (maybe 3-5 seconds) being on high, I heard something in the light begin to sizzle. I felt a shock like a small explosion within the light. I dropped the light and as soon it fell on the floor it sounded like loud firecrackers popping. I jumped onto the bench to cover myself. There was one loud boom. When the smoke cleared, I was in shock with so much glass around me. I inspected myself and found blood dripping on my left leg above the front side of my ankle, 1 inch cut on my left arm, 1 inch cut on my right side chest all caused by the shrapnel from the explosion.
Inspecting site where the explosion happened. The rocks on my balcony (where the light was dropped) parted from the explosion leaving an imprint. A few parts of the light were barely distinguishable.
In summary, if a battery can do this:
In the pictures you can see that the explosion was very powerful to dent the railings of the sliding door. Crack 3 panels of glass ¾ inch thick. Send glass shrapnel flying to get imbedded in a cement wall.
If you wanna get into LED flashlights and their associated batteries, you'd be best to buy good quality.
dx.com
like these
Could the aluminium PCB be cut into 4 strips? each with 7LEDs @ 24V and ~300mA for maximum of 7W input?
like these
like these
Why bother? just buy a strip:
High Power 16W 950LM LED Emitter Metal Strip (12~14V) - Worldwide Free Shipping - DX
There are many many other kinds on there just search for "led strip diy"
LOL. Did you just tell SY to look up the Red Light District amp? Or was that for the rest of us? 😉o go off the deep end, look up Red Light District tube amp and you will see what a few hundred can do.
The Red Light District: A 15W Push-Pull Amplifier
It should be noted that I did buy a LED night light today so I can stop having to turn on the light every time I need to get up to take a leak, and I rather loved the colour output of it and brightness of it too:
The colour shown is accurate, it looks like the closest candidate to incandescent that I've seen so far, picture was taken with an ipad 3.
So far I've been lucky with Li-ION batteries. I often measure cheapie chargers if they are within spec (most aren't) and get modified or junked if they exceed the 4.2V open circuit spec. These days, I buy AA powered lights as they are far more practical as you can buy AAs everywhere. No need for specialized batteries.
Indeed, I've standardized myself on AA aswell, its got the best balance of weight/power density/size. You can get dual chemistry flashlights on dx, ones that will run fine on 1.2v NiMH or 14500 Li-Ion rechargables.
Though for my bhi DSP project I've used 2x 14500's in series inorder to create the required 8.4v nominal to power 3x devices at the same time but also manage to not go outside of specifications on any of them, one has a voltage limit of 9v, the other 12v, etc. The lifetime per charge is also exceptionally long. For small projects, Li-Ion rechargeable just can't be beat for size/weight/power density Vs NiMH...
The project uses 2x FM receiver modules + 1x bhi DSP board + 1x LM386 amplifier board.
It receives audio from a radio receiver via a cheap FM transmitter dongle that I bought off ebay on 87mhz, it receives this transmission through one of either the two FM receiver modules (switchable between), then the output of the FM receiver module is fed directly into the bhi DSP board, then the output of the bhi DSP board goes to the LM386, and the LM386 is set at a low gain that then goes to a mono headphone output.
I wish C was more popular than it is though.
D is pretty much useless nowdays. Though I still have a Duracell Dolphin light hanging around that takes lantern batteries, you just can't beat a nice big reflector and an incandescent globe sometimes, that and its waterproof and cheap.
MTBF is not the expected lifetime, but the average time between first failure and second failure of a system. See this wiki.
No, this is lumen depreciation, the opposite (how much light is left) is lumen maintenance.
As an example here's a link to the specifications of a simple low pressure sodium lamp. Among the specs are the expected lifetime at failure rates of 5%, 20% and 50% and the lumen maintenance at 2,000 and 5,000 hours.
They seem to be getting better. I've seen strings of white LED Christmas lights that were a cold white and others, seemingly identical when off, that looked incandescent when powered. So much so, I had to look very closely to believe they were not "real" Christmas lights.The colour shown is accurate, it looks like the closest candidate to incandescent that I've seen so far,....
LED Standardization
Hello folks,
Well today I was asked at work to do some LED research and low and behold there is some LED standardization going on.
http://www.zhagastandard.org
Of course, it looks like Philips is behind this, along with many other large and some smaller OEM's but it shows that these folks are starting to address this very important issue with regard to this technology.
Also found this, as well
LED street light / road light fixtures using LED light modules by Philips Lighting
LED mfg's & the consortium have standardized hours until lumen depreciation meets 70% of initial
BTW a F54T5HO lamp depreciates to ~95% over its life span,~20-30khr, a huge difference in performance, this is why they are the #1 lamp used today for high-bay applications, lets see how long it takes for an LED to displace this technology.
Rick
Hello folks,
Rick
Hello folks,
I stand corrected, apparently the manufacturers do see the advantage of standardization after all. I still doubt that this will be the case for consumer LED lighting products, but who knows...
Could you check this link? It doesn't seem to work.
A logical choice as "The appropriate lumen maintenance target is usually based on the application and the requirements set forth by customers. Since the human eye generally can’t detect a change in light output until there has been 30% depreciation, L70 is often established as the target for an application." (source).
Also "CFLs produce less light later in their lives than when they are new. The light output decay is exponential, with the fastest losses being soon after the lamp is first used. By the end of their lives, CFLs can be expected to produce 70–80% of their original light output. The response of the human eye to light is logarithmic. One photographic "f-stop" reduction represents a halving in actual light, but is subjectively quite a small change. A 20–30% reduction over many thousands of hours represents a change of about half an f-stop. So, presuming the illumination provided by the lamp was ample at the beginning of its life, such a difference will be compensated for by the eyes." (source)
That might be shorter than you think. Granted, for existing installations the most economical solution (for now) would be to replace the lamps when they're nearing end of life rather than replace the luminaires by new ones. When it comes to new installations or renovation, then perhaps the choice for LED luminaires is more easily made, especially if the price has dropped some more.
Those F54T5HO (or TL5 HO, 54W as I know them) have a lamp luminous efficacy of about 90 lm/W. Luminaire efficacy will be lower than this because of the losses in the ballast and optical losses in the luminaire.
Here's an example of a LED highbay luminaire with a luminaire luminous efficacy of 82 - 91 lm/W (depending on the version). The lumen maintenance after 40,000 hours is still 90%, when you're already through most of the life of the second set of F54T5HOs.
To adress lumen depreciation, I've read of luminaires equipped with "CLO", i.e. constant light output. End-of-life output is treated as target light output and new light sources are dimmed to that level, in the process power consumption is also lowered. Then, as the source ages, dimming is gradually lowered to keep the light output at the desired level.
- General Interest
- Everything Else
- Are you interested in LED light?
