Are two resistors in parallel better sonically than one?
In several schematics such as the F5 circuits there are two parallel resistors specified instead of one. For example two source resistors of 1 ohm 3 W each resulting in 0.5 ohms 6W. Is this better in some way than using a 0.5ohm 6W single resistor?
Thanks.
Nash
if voltage distortion is a consideration then two series connected resistors can be a benefit.
This advantage does not apply to paralleled resistors.
If power dissipation is a consideration then either paralleled, or series, or series/parallel all benefit equally from the reduced power, after sharing the loading.
Thanks.
Nash
If the resistors are wire-wound type, the combined inductance is reduced in half also. That may affect higher frequencies.
