Are those distortion values ok?
I measured my system distortion with rew using impulse response, using lenght=1M as suggested in REW's docs. System is composed of a subwoofer, woofers in the doors, mids and tweeters in the a-pillars. Crossover are 75Hz - 400Hz - 3.5kHz.
These are the results (it is the same measurement but plotted differently, one for SPL and one for distortion % for easier visualization - white line is THD):
The spike at 200Hz (3% THD at 80dB) is volume-dependent and I'm not sure if it's the speaker itself or the plastic panel of the door vibrating. The spike at around 1.6kHz (1.7% THD) is not volume-dependent, it is always there and corresponds to a dip in the frequency response of the mid, I'm still trying to understand where it comes from. Anyway the overall THD is mostly below 1% but sometimes higher than 0.5%.
I'm not an expert in car audio at all, unfortunately I could never hear a proper setup and I couldn't find any similar graph on the internet (I can only find THD measurement of the amps, but not of the speakers) so I wonder if those distortion values are considered good for a medium-quality system.
Any suggestion for improvement... Thank you.
P.S. The subwoofer is turned off in this measurement
