Are LM3875, aka gainclones, chips suitable for a car amp?
kinda hard to get an answer to a lot of questions nowadays.
they would be suitable if your speakers are over 4ohm and if you can provide the required voltage, which is not that easy. have a look at the datasheet for the minmum voltage and for the voltage vs impedance vs power graph
I used one in my 1987 MB420 -- for newer cars you should really take heed to make sure that the SMPS is well shielded, that the supply lines to the battery have the proper chokes -- you could probably shut down any new microprocessor controlled car with all the RFI which an unshielded SMPS creates.
Well, I sure hope so.
I'm currently very happy with my commercial car amps, but I'm thinking about bi-amping everything in the future, and that means that I'll want more channels.
On the drawing board is 8 channels from LM3876/LM3886 chips, which are very similar to the 3875s. I'm planning to use the 3876 chips for tweeters and center channel, and the 3886s for midranges and woofers. Subwoofers will either remain as they are, or be changes over to a beefier diy transistor amp capable of delivering a bit more power to the 4 ohm voice coils.
All speakers are planned to be 4 ohm, but with the bi-amping, I'm hoping that none of them get pushed hard enough to cause a problem.
Actually, I looked a little closer and found out that LM3886's are rated for 4 or 8 ohms. LM3875's only have ratings for 4 omhs on the data sheet. Btw, LM3875's actually have a higher power rating than LM3886's contrary to what most people think.
