I wonder if a CLC (or CRC) filter will be okay for a class B amp or preamp (or anything else, since it's not class A (no constant current load)
since the drawn current isn't the same all the time, the voltage drop across the L or R won't be stable, and output voltage won't be regulated anymore?
As a practical matter there are a lot of well-regarded amps out there that aren't Class A and are using CLC or CRC filters. Dynaco MkIII and ST-70 come to mind.
CRC is only good for class A, since current is constant, and thus voltage will remain constant. CLC is far better, not just from efficiency, but its regulation is much better too.
Tim
Tim
Far better... for class A?Sch3mat1c said:CRC is only good for class A, since current is constant, and thus voltage will remain constant. CLC is far better, not just from efficiency, but its regulation is much better too.
Tim
Uh, far better where regulation is needed, but preferable in any and all cases due to the efficiency.
Tim
Tim
How does one deal with the inductor current rating for selection of a suitable inductor?
I think most inductors are rated in mA. If my amplifier is drawing a quiescent current of approx 3A, what kind of inductor rating should I be looking at?
It's also preferable for class A designs but NOT because of the class of operation.
Ah...O.K.
For any class of operation overspecify them and you'll be not only safe but they'll sound much better too.
Running magnetic components close to saturation is not a bright idea IME.
Cheers,😉
Ah...O.K.
Cheers,😉
I have a boxfull of toroidal mains transformers. Would I be right in thinking that I could use the secondaries of a couple as inductors in a C-L- R filter, taking care of course not to exceed saturation (which I expect would be higher than the rated output)?
I'd connect the primaries to neon lights so they flash when the amp is turned on ;-) ...nah, maybe better just to snip the wires.
- Design & Build
- Parts
- Are CLC and CRC filters any good for anything else than class A?
