ARC's decoupled EL cap Patent???
is this just hocus pocus or is there something to this?
Well, no rocket science as usual, but at least no complete B*S$ either.
Here is a direct link
Patent US5036292 - Decoupled electrolytic capacitor - Google Patents
The results of doubling a large cap with a small one are well known by people familiar with these problems, but the vast majority simply continues to bypass any lytic with a 100nF, and for those, such an innovation is probably a great step forward: it is ready-made, and has the gloss of a" patented technology".
Search this forum for this kind of topic, I have posted a number of actual measurements.
the inductor is not in series with the lytic, it is shunting the electrolytic.
Looks like a basic LC resonant circuit... with a resistor to lower the Q.
Fig 3 for example.
Of course it will work only over a relatively narrow range, then it gives way to being a simple RC...
Patented, eh?
_-_-bear
"A filter capacitor network includes an inductor connected in series with an aluminum electrolytic capacitor with the inductor and aluminum electrolytic capacitor bypassed with a capacitor having relatively better high frequency performance characteristics than the aluminum electrolytic capacitor."
With properly chosen values, it can improve the overall behavior of the composite.
It is better than simply paralleling the caps without any precaution.
The effects of such a paralleling can be seen here:
http://www.diyaudio.com/forums/powe...lm-caps-electrolytic-caps-17.html#post2257381
With adequate values, it can shave off ~20dB of the nasty parallel resonance peak (the most troublesome).
Note that the values of this example are rather preposterous; within the scope of the patent, one can certainly do much better.
It's always hard to tell the phase from the amplitude with multiple plots in LTSPice... so I don't know what the curves are showing?
Solid=amplitude, dotted=phase
Also what does the left most circuit represent? The self resonance of an electrolytic? Then the right one is "with" the patent circuit applied?
100µ // with 10n, without (red) and with patent (green)
_-_-
