Comparing PCM and DSD is pointless, second one has far more 'natural' way of encoding music data..
For whatever "natural" means. I guess in this context it means "hard to process", as in requiring it to be converted to PCM for processing, and then back again...
Someone hears a difference, someone else does not, someone just claims to hear.. but this is no proof or argument..
Indeed...
No, the more I thought about how the human brain processes the information that gets from the ears .. much closer to the DSD encoding method..For whatever "natural" means. I guess in this context it means "hard to process", as in requiring it to be converted to PCM for processing, and then back again...
Not really. At all.
What you hear are waves of air pressure, not a pulse-width-modulated sequence of high-frequency pulses.
The human brain is 1-bit digital and not analog devices..Not really. At all.
I'm not talking about how ear works..
I think this analogy is being stretched to the snapping point.
Even if your analogy was true, the DSD bit stream never reaches your brain - what the speaker sees is a continuous analog waveform. There is no way (apart from HF noise and frequency response irregularities) to tell from the speaker output if the signal driving the speaker came from a PCM or DSD source.
Anyway, this has very little to do with Archphile...
Hi all,
I thought that it might be interested to share with you my experience so far with DSD reproduction alternatives:
MPD package with SACD/DVD-A ISO support - Blog - Archphile
MPD with native DSD mode support - Blog - Archphile
Although native DSD support is still under development, it appears that SACD ISO support works ok for many Archphile users.
However, in my opinion the best practice is always to convert the ISO to dsf files. This way you can get rid of the multichannel part of the ISO and free up disk space.
For anyone that wants to test the sacd ISO package, please not that it's an unofficial and experimental package. In addition it's not vanilla MPD but an MPD fork created by Maxim V. Anisiutkin.
Hi all,
after a long time I am really happy to announce that I am working on the next Archphile image. There is no ETA yet, but I believe that it will be ready in the next 30 days.
Some worth noting details:
Last but not least I have prepared some unofficial packages that will be in playground repository for squeezelite and LMS. I will not support these packages but feel free to experiment with them as it will be very easy for MPD and squeezelite to coexist in the same system.
Currently I am doing all development and testing on my new Odroid C1+ and in the next days I will start transfering all the optimization to the RPI, Cubox-i and Udoo Quad.
There is also a blog post explaining some of the above features, but it's already outdated as I have added stuff after that:
http://archphile.org/blog/details-on-upcoming-archphile-version
Michael
- Support of ODROID C1+
- End of support of the old Raspberry Pi (arm6)
- latest MPD 0.19.11 with the less possible configuration options enabled for a minimal result
- latest MPD fork with SACD ISO support (not installed by default)
- latest YMPD from github sources with various changes (the most noticeable being dirble support)
- replacement of shairport with shairport-sync (ios9 compatible)
- many backend improvements (custom IRQ affinity for each board, setting MPD to use 1 core for all it's threads (with taskset), option for usb disk sleep etc)
Michael
Any chance of "porting" this excellent project to x86 systems?
I've listened to Archphile on a friend's system and it sounds great. But I have a lot of money invested in PC hardware and I'd like to try
Sent from my D5803 using Tapatalk
E.g. voyage-mpd Voyage MPD | Voyage Linux , just add the ympd from git https://github.com/notandy/ympd .
Archphile 0.99.4b Beta is up for all supported boards:
- Raspberry Pi 2
- Odroid C1+
- Udoo Quad
- Cubox-i
0.99.4b is up for R Pi 2, Odroid C1+, Cubox-i and Udoo - Blog - Archphile
- Raspberry Pi 2
- Odroid C1+
- Udoo Quad
- Cubox-i
Hummingboard also working (set card to 0 in asound.conf, device "hw:0,0" in mpd.conf). Big improvement and my preferred distro.
A new image for the Raspberry Pi is up. The main change is that I have replaced my custom kernel with the defaulte ArchlinuxARM package as the patch I had applied on my kernel package for i2s was not needed. For more details please read here:
An apology to the community and a new version for Raspberry Pi 2 (0.99.4c) - Archphile
New MPD and ffmpeg packages are up:
New MPD and ffmpeg packages available for update - Blog - Archphile
- mpd-archphile and mpd-archphile-minimal were updated to 0.19.13
- ffmpeg is updated to version 3
- all mpd-archphile-native-dsd and mpd-archphile-sacd remain in old versions but were rebuilt in order to use latest ffmpeg
Michael
Michael
New MPD 0.19.14 packages are up:
MPD 0.19.14 packages are up - Archphile
In addition I would like to let you know that I am working on an Odroid C2 image which is going to be uploaded (hopefully) very soon.
Michael
Michael
The archphile image for odroid c2 is up:
Archphile 0.99.5 alpha for Odroid C2 is up - Blog - Archphile
Thank you tuxx! Archphile is working flawlessly with rp2. Even sacd iso files play smoothly. Great!!!
- PC Based
- Archphile - An Archlinux Based Audiophile Distribution for Raspberry Pi and Udoo Quad
