The amplifier switches into the protection mode after a random time and comes back again. Sometimes the display shows the error message DC OFFSET error. After measuring the DC-OFFSET, both amplifiers (Left and Right) go through the same DC OFFSET variation. Because both DC OFFSET (Left and Right) show the same wrong behavior, it has to be a powersupply problem.
The -15V supply was not stabel. I changed the regulator REG202 and cap C218 but the problem was not solved. After mesuring I found out that ADJ pin of REG202 was floating. An inspection of soldering pointed out that R214 was soldered at one site. So I resolder the end of the resistor and it's fixed.
Arcam is not badly designed junk at all
Looks like one that got through the soak test... leadfree rubbish doesnt help
