My Arcam 8R is blowing the main fuse.
I found that the right channel MOFFSETs had short.
I replaced them and now they get really hot within a few seconds and blowing the fuse again and also blowing the MOFFSETs too!
I checked the main diodes and they are ok.
What drives the MOFFSETs crazy, is there anything else you would suggest I check?
I attach the service manual.
No I have not would it make a difference after replacing the MOFSETS but can I do that without the MOFSETS in as they will blow off if i solder them on
When outputs blow they tend to take other components with them. So I would start from board wide component check before burning another set of outputs.I found that the right channel MOFFSETs had short.
