AR ES1 Rega 250 Arm Mounting
I have just purchased a RB250 arm for my AR ES1 TT then I found out that I need almost 3/8 inch elevation between the arm board and the base of the Rega arm. Is this normal and what type of washer you use to make up the thickness? I appreciate any help you can provide. Thanks.
Tin Man
