AQ1200
What is the best course of action when everything seems fine but there is no audio output?
All drive signals on the outputs look good.
All power supplies are there.
Relay kicks on and amplifier shows a green light.
The only real strange thing I see is there is "ringing" on the signal at the top of R33 on the output card.
The compression software lacks something to be desired, but you can see the drive signal.
It looks like it is modulating. I am inputting a 50Hz sine wave.
Notice what happens when the relay clicks in.
  • freecompress-20250526_135438.mp4
    2.6 MB
I re-flowed the solder on L205 and L203 and all other suspicious looking joints in the output.
I checked the functioning of the relay. It is fine.
The signal is not making its way through L203.
Could there be a short in the inductor?
Perry, I want to thank you for your patience.
I believe that I have got this amp working. I am putting it back into the heat sink for more testing.
I do think that there was a bad solder joint, but it kept acting "flaky".
I started moving the gain pot ( I had it set to the center while I was checking) and low and behold, I have a good signal all the way through.
Reactions: Perry Babin
