Approaching noiselessness with the LT3045
Hi all, somebody can help me to identify this LDO regulator ?
Thanks by advance
Ano
Reactions: sercan85
Hi and many thanks for your reply, I suspected it a little but I actually have LT3045 but with a different screen printing (LGYP134246) why do manufacturers use different code?
Thanks for your help, did you use this LT3045 ? I would tu use with a transistor for increase the current.
Best
Yes i use lt3045 and 3094 on my amplifer. Amplifier power is 43vdc so i use 18volt transistor and zener after lt30xx set to 15V. I will share my amp on diyaudio very soon. My design is a much better alternative than Lm3886.
"I placed the LT3045 and 3094 regulators in a PCB using 7815 and 7915 packages. Since the input voltage of the regulator is higher than 20 volts, I used a pre-regulator of -18 and +18 volts. The output of the LT3045 and 3094 is 15V."
