Applying Thermal Compound
Joined 2019
I have noticed that some amplifiers have thermal paste applied down the entire length of the heat sink.
When reapplying thermal compound after working on an amp is there any benefit to putting it back like original (all the way down the sink), or is it okay to put only under the components 'in contact' with the sink when reassembling?
It makes no difference in the reliability of the amp. It's likely quicker for them to paint the entire length than applying to individual locations or to the transistors.
The only benefit that I've seen is that it will catch and hold tiny wire strands which can cause the amp to fail. You don't hear about wire strands much in the amps here but I had a LOT of amps with strands in them.
Reactions: BIGDOGBRODAVE
Good point! I didn't think about it possibly catching debris.
My thoughts were centered around the fact that a 5 oz. tube of DC 340 is $63.00 on Am*@on right know. Arrghhhh!
I agree, I bet ~ 50% of the amplifiers I have opened up for the first time, I have found at least 1 wire strand somewhere in it.
The current one I'm working on had several pcs floating around inside.
An example from a Rockford amp.
If I were to see that many wire 'hairs' stuck to the thermal compound, I would immediately blame the last tech to work on it! Funny that there hasn't already been trouble.
As for the amount compound needed, it is likely a bit less than you think, and if 'extra' is squishing out of the sides when the transistor is tightened down well that is just waste.
"Haha, For me it seems to have an affinity for everything!"
Is it so bad that you even find it in your Never-Seez?
"I would immediately blame the last tech to work on it!"
When people stripped wires over the amp, the gaps around the edges of the cover would allow them to get into the amp.
