APPJ PA0901A Repair
Unfortunately a shorted valve has sent an SMD component up in smoke in my APPJ PA0901A.
Currently the amplifier is
  • Distorting on one channel driving speakers, however it drives small loads fine.
  • Oscillating on one channel, which sounds like a beating heart, but only when the amplifier is turned off and back on after the valves have warmed up.
  • When turned off the left channel fades away in a few seconds as normal and the right stays at mostly the same volume and plays with less distortion for several seconds.
I've attached a picture of the blown SMD component, the opposite component
has '431' printed on the top of it, Is is safe to assume this is an LM431? Also from what I've described above does it sound like the shorted valve has taken anything else out, should I be replacing other components as a matter of course when repairing it?
