Anyone using a PA amp in their home system?
I'm running an AB 9620b and absolutely love it. Bought it used and abused, got it repaired then installed new volume pots, swapped out the audio films for metalized polypropylenes and recapped everything minus the giant power supply caps and it's very clean and neutral sounding. Thing is a helluva a deal.
I have 2 new zealand made HOLDEN 300 watt mono amps, I use these for pa for the band they waigh a ton BIG heat sinks no fans, will run flat out all day with out overheating. but the band only proformes once every month or so (being purly amatures) so the rest of the time they are my sterio at home for sum reason I never seem to turn em up far
Hell yeah!
Old school 93 pound Crown M600's in my living room with the infinitely variable fan option and a Crown I-Tech 5000 HD in the office, with a fan that idles fairly quiet but goes full tilt for a half a second once in a while just for fun seemingly.
Barry.
We use the Crown I-Tech amps at work, which is how I ended up with the old Crest amp.
The Crown HD are rather nice, with good built in processing. Just stay away from the 4 channel model. Every one we own has failed.
