anyone using a battery powered pre?
I was putzing around the ESP site and found a neat circuit for a float chatger and another for a sensor circuit to disengage the charger when it sees "turn on" of an amp or pre. I've got a couple of 100Ah SLAs but when I looked around last night I could not find a pre that uses a 12-0-12 supply. My current pre's, Kenwood L-07 and B&K Model 1, are pretty good but it would be nice to DIY if the results would be worth it. All I'd need would be line level.
TIA, John..
Battery Preamp
Hi John,
I do. I've built several preamps with great success, but none as clean and flawlessly noise-free as my current unit powered by two 12V, 1.2Ah Gel Cell batteries.
The preamp design is a very basic op-amp design with much attention paid to quality and precision. I use a Burr-Brown OPA2604 (my next design is almost done and uses an LM4562) op-amp, switched attenuator, very clean grounding, and decent Teflon wire. All components are hand-matched and are decent quality parts, but nothing fancy with big (expensive) names. I simply used what works and measures well.
The two batteries form a +/- 12VDC supply that is heavily filtered due to the nature of Gel Cell's impedance to rise with frequency. I use an off-board charger that I plug in after every 20 or so hours of use. The battery-supply provides an absolutely noise free voltage source that is ultra stable and has extremely low impedance accross the full audio band. I have never measured a regulator circuit, regardless of design or complexity, that is as "quiet" as this battery circuit.
You mentioned 100Ah batteries - um, slight over-kill, but will still give you +/- 12V. Most preamp designs will run just fin off +/- 12V, but will limit your output voltage swing to about 4VRMS. Still, that's more than adequate for most any commercial amplifiers to hit full output. I highly recommend trying it - you may never go back to regulators or mains-powered preamps again.
Cheers
paulb said:
Mercator and I are in the middle of building one. We're also using 2x12V batteries. We're using different gain blocks. I can send more details if you like.
Paulb
Yes please. I already have the somewhat large 100Ah batteries so I guess I could use Class A if I wanted to. Heck, I have a dozen of them. I just want to try something different.
John......
Battery preamp
Hi scottw,
No inductance used. My goal was to have very low impedance across the entire audio band so the op-amp does not need to rely on PSRR. With an inductor in series, the problem would be compounded at higher frequency. So, I use 16mF (yes, milli) electrolytics plus 4 x 100nF mono-ceramics parallel with each battery. I also use additional mono-ceramics, small electrolytics, and tantalums from rail-to-rail. Take a glance at my avatar – that’s the actual PCB. It’s overkill, but at a DIY level, the cost is not an issue and the performance is outstanding. With my scope at maximum resolution, signal ground, +Vcc, -Vcc, Vin, and Vout are indistinguishable with effectively zero noise. Zero noise at Vout is, of course, with 0dB attenuation. Every mains-powered preamp, regardless of design, and every regulator circuit, regardless, I’ve tested clearly shows measurable noise under the same test conditions.
I’ve seen inductors used in car audio, 12VDC stuff, but that’s more intended to reduce alternator ripple and charging noise. In car applications, higher impedance at higher frequency is desirable.
What else can I say? My preamp is as “noiseless” as I can measure and hear, and is as close to a passive preamp in clarity, but with gain and a low Zout, as I can get. 2Hz to 200Khz, 13dB of gain, 24-step attenuator, 90dB separation, and non-existent coloration. I don’t have equipment measure distortion, but I’m pretty sure it way, way down there. I love listening to music through it. It is truly a pleasure to use plus that DIY comfort knowing it could probably go head-to-head with $1K “audiophile” units and do very well.
Best regards
The two preamps we are building will use different gain stages. Mercator's using an ESP P88, while mine will have a Valkyrie board from an article in AudioXPress (actually probably Audio Amateur) many years ago. Dave oops I mean Mercator's P88 uses OPA2134 op amps. Both will have differential input and outputs, based on another ESP design, in addition to the single-ended ones. I may end up using mine mostly as a headphone amp, with the differential output for audio distribution through my house.
We're using a capacitance multiplier on the audio power supply rails, and a charging circuit, based on 2 TI UC3906s, that charges when the preamp is not being used. Input switching is done using reed relays, volume control uses a motorized pot. I will use an RF 4-button remote, while Mercator will control his from a PC that itself has an RF remote. The control / charging power is completely electrically separate from the battery/audio power.
Pics and cost
I've got about $65 into it not including the charger. The Alps stepped attenuator was the most expensive at $25, with the batteries second at $24 with shipping, and all other parts in the $1-2 range each.
Attached are a couple pics - not much to look at, but sure does the trick.
A good battery power Tube Preamp
Someone used battery for grid bias but I used battery for supply my Tube Preamp by switch mode power supply from 12VDC to 275VDC
Quiet background and support hign frequency response more than tube regulated linear power supply !
analog guy
