Anyone use a old Hayes 14.4 Aluminum chassis to build a GG?
I have two of them, so I can build a couple Monoblocks. Only issues at this point are power supplies, since I dont think theres a Torroid that will fit in it. (have to see) Probably have to build an external PS................
purplepeople said:
Sounds cool. Now I have to dig up a pair of old modems - maybe at a garage sale. I was originally thinking of using an old 5-1/4" plastic floppy case.
Do you think there is a source for used surplus cases?
🙂ensen.
Do you have Goodwill in Canada? Or a similar thrift store chain? The ones down here in the states always have all kinds of old computer equipment. The non-chain stores don't seem to get as much in the way of electronics, but Goodwill just gets tons and tons of that stuff, so definitely check there if you're able.
In addition to old modems, you might keep your eye out for old external disk drives. External SCSI boxes in particular are usually very well-built and would probably make a good amp chassis.
