This little kit keeps getting my attention. Anyone tried modifying it to Ultra-Linear or Triode-Connected mode ?
percy said:This little kit keeps getting my attention. Anyone tried modifying it to Ultra-Linear or Triode-Connected mode ?
Are you talking about the S5 Electronics kit? I have built one and think it sounds very good, especially for $140.
However the OPTs supplied with the kit don't have UL taps so you'd have to replace those. No idea about triode connected mode though, never crossed my mind.
I had thought about replacing the OPTs with a pair from Uncle Ned just to give it a listen. He has a P-P OPT with UL tap and it looks nicer than the open ones in the kit.
http://store.yahoo.com/triodeel/tf65wscta48o.html
Yes I am referring to the S5 kit but didnt specifically mention that as the same kit is available from a two or three different vendors.
I recollect from my earlier findings that the OPT primary Z should be 10Kohm. But if you change to UL or triode I believe that will change.
Tom, have you done the UL mod ?
