I have built amps with these. The big problem with them is their sensitivity to both DC and AC imbalance. This is especially a problem when applying GNFB around the amp as it can exacerbate core saturation during large transients.
The best sound that I was able to get from these involved PP class-A DHT output stages with no feedback. In that application they had superb transparency and low level resolution (assuming you had a clean B+).
While that is no doubt true for any OPT, I found it to be especially the case with the Plitrons.
I have. They have very low winding DCRs so they work very well for making an amp without global feedback that still has a low Zout. My amp's Zout is just over 1 Ohm, no feedback around the output transformer. It is a Unity-Coupled amp so it has very heavy local feedback in the output stage that drives the transformer.
I also tried to find the -3dB point on the low end and found that my measurement setup could not get low enough. I was still at full amplitude at 10 Hz. This was small signal bandwidth. The transformer spec was for -3dB @ 500kHz on the high end but my driver stage ended up limiting my amp bandwidth to 120kHz. Probably not a bad thing.
I used the Guido Tent/Van der Veen bias servo to maintain tight DC balance. It works very well but adds a minute or two to the time it takes for the amp to be ready to play music. It starts at full negative bias with a delay until the tubes warm up and then slowly reaches target bias current, about 30 seconds after the delay times out.
