well, any speaker can be mounted in open baffle. Doubling it, it increases the production of interference ( waves? )
The particular arrangement that you show is a typical OB one: two 15 inches and a fullrange, both having HiSPL and not necessitating active correction.
Edit: UH, that's not the ubiquitous PureaudioProject or likely...that is the ESS tweeter, so that's a true D'Appolito and so on, and YOU would want the Audax woofer work above the 3 low octaves; C'mon !! DO the pureaudioproject, you can find the WAW idea in the Fullrange Forum either
Hi Barossi,
I think the ESS is too low in position in your example, but maybe that´s just me.
Even two poor small Auday 210 will make absolutely no bass. If you force them to do so by DSP, you´ll end up with very low output.
You will need to add 2 15-inch-drivers at least to match the ESS, like in your picture. If you choose the right drivers, you won´t need the Audaxes.
By the way, 400 Hz is too low for the ESS, or have I misunderstood something?
Good luck
Mattes
Good luck
Mattes
