whatever you swallowed
Are you a total nut job, and scared of being dragged into a white van and driven to an asylum, with a single room and full board on the house, plus complementary straitjacket ?
Tell each and everyone you're an Audiophile, no one will even touch you with a ten feet pole, problem solved.
The cables all have arrows on them pointing in the direction of signal flow. The arrows on your cables should point away from your source and toward your destination/output.
But he said all music is AC?
I always just assumed that "directional" cables have an overall shield that is not connected on one side.
You can find a lot of dubious BS from that guy on youtube, under the name oddiophile and his actual name. One suggests using brass screws, presumably because nonmagnetic, in speakers and a torque wrench...
- Member Areas
- The Lounge
- Anyone swallowed poison? Need to get it out?
