I recall someone stating they measured the Eminence Killomax 18 in which the QTS was 0.7 with an fs of 38 Hz
Has anyone measured the Eminence Killomax 18 TS Parameters and know the VAS, QMS, & QES.
I think there is a new one at the shop I can test. I just need to find my testing jig. I'll get back to you and let you know.
-Matt
-Matt
My experience with Eminence drivers is that the parameters have been pretty spot on. There will always be some variation in compliance put it sounds like somebody was measuring a driver that wasn't broken in or was in a cold environment etc.
Cheers for that.
I just want to confirm that the figures are not so off that the woofers will give me a totaly different response than what I am expecting.
+1
Good. It's always best to measure your driver before you start cutting wood.
Haven't seen any, though these are high compared to published: http://c3.zzounds.com/media/kilo18-10c4f5c0757e9b572f14fc49969c3e37.pdf
GM
GM
That is the old specs/model when they offered the green stickers. The new model was revised and offers a black sticker on the magnet. Looks like I will just have to bring my laptop and test them in the store before buying.
Hmm, when I searched Eminence.com the other day it didn't show a current model, so thought it discontinued, hence the specs I linked to.
Going back just now and looking up the pro series shows an 18A with even lower specs, which in either case is too far off from Eminence's normal tolerences IME, so looking forward to what you measure.
Speaker Detail | Eminence Speaker
http://www.eminence.com/pdf/Kilomax_Pro_18A.pdf
GM
GM
- Subwoofers
- Anyone measured the Eminence Killomax 18 TS Parameters
