I'm thinking of doing a ptp wiring tube project and happened across this:
DIY 6922 / E88CC Tube preamp
Anyone know where to get that kind of proto board and solder pins / component stands? I love how the pads are spaced out and how that lends itself to a nice clean layout. All the proto boards I see have the pads too close together
Try here:
Vacuum Tube prototype / project board for 9 pin tubes
or ebay:
http://www.ebay.com/itm/VERO-BLANK-PROTOTYPING-PCB-C-BOARD-TUBE-AMPLIFIER-/380173052971
There are others on ebay as well.
or ebay:
I already found the first link in my search. Couldn't find anything there. The board on ebay is closer, but not quite it. It appears that the board in question is tinned with silver...as it has that characteristic flat appearance.
I also wish I could find those copper standoffs...they're nice.
Tubes and More has a tinned version that looks similar:
Turrets - for 2mm boards | Antique Electronic Supply LLC
Those look nice. Thanks.
Antique Electric has turret boards and the staking tool for setting the turrets. Have you seen those? http://http://www.tubesandmore.com/products/terminal_boards_strips
I really like the board in the photo but did you notice he had to drill out the holes for the turrets? They use 1/8 inch holes. I'm not certain how he made the connection between turrets - under the board???
A proto board with the proper sized turret holes on a common pad with multiple holes of both turret and typical component size holes would seem better. I think Something like that would be very useful for integrating sand and tube designs.
- Tubes / Valves
- Anyone know where to get this type of breadboard?
