Anyone know of a US source for ESL toroids?
Followup: A week or so ago I emailed Antek asking if their 50VA 2x115V / 2x6V toroids used grain oriented cores and what the insulation values are between prim/prim & sec/sec windings but I've gotten no response so far. I suppose at $13 a piece they're cheap enough I wouldn't get burned too badly if I bought some to play with-- which I may do that at some point but for now I'm gonna keep looking for 230v/6v toroids with single windings; although I expect it will be hard to find a source that will ship to the US.
It's not like I'm desperate to find some-- just curious if changing from my current 100:1 EI core trannies to a tandem 68:1 toroid setup would improve my speakers' high frequency response. I like a lot of treble, since I'm a bit treble-deaf, and I'm having to add quite a bit of EQ boost above 5khz to get it where I like it.
Again-- If anyone out there finds some suitable cheap toroids available here in the US, please let me know. Thanks all!
Geeze, I hope you're kidding.... thanks for the tip but your suggestion presumes that I would know what wire sizes to use and number of turns needed--- sadly I'm completely ignorant about all that stuff. Actually, I had thought winding my own but all the info I could find on it wasn't geared to ESL applications so I really wasn't able to learn anything. Old dogs don't learn new tricks easy anyway.
The smiley face was meant to assure you I was kidding, but only because it was clear from the beginning of your thread that making a transformer from scratch wasn't what you were aiming for. I'm sure we could each figure out how to wind a transformer as Sheldon describes, but I don't currently have the expertise to make intelligent design choices any more than you do. Maybe someone else can chime in with a way to distill the design choices down to something newbies can work with. Until that happens, I'm with you in your quest for a source of relatively inexpensive toroids that'll get the job done.
Few
Calvin,
Can I use a standard 50hz step-up transformer for a full-range ESL?
I am an American living here in Beijing right near the "Silicon Valley of China", which is an electronics market with a goldmine of every kind of component for cheap.
I was just there today looking at tons of giant El and toroid transformers, but when I told them I wanted to use it to step up a 20-20K hz audio signal they told me it wouldn't work because they were designed for 50hz. Is this right?
What specs should I look for in these transformers here to find some that will work for ESL's? These places can even custom-make them for me, but they seem very confused by the 20-20K hz issue and seem to only make standard 50hz transformers.
Thanks!
Q: Can I use a standard 50hz step-up transformer for a full-range ESL?
A: probabely not, but not because it is designed for 50Hz usage but because of a too low primary inductance and maybe wrong core material.
You need lots of primary inductance to reach down to 20Hz, more than normal power trannies have. For hybrid panels working >200Hz prim inductance is usually sufficient. The core should be wound from thin grain oriented material, not ferrite or similar. Then bandwidths >20kHz are possible.
jauu
Calvin
Calvin, thanks for your answer!
1) "too low primary inductance"--what value of primary inductance would I be looking for to reach down to 20 hz? What determines the primary inductance, and is it helped by having larger toroids, i.e. 100VA or more?
2) A core of "thin grain oriented material, not ferrite or similar"--what specific material should I ask for ideally?
The great thing about these markets here in Beijing is that I can have them custom-make almost anything I want. What are the idea specs I should ask for for ideal trannies for full-range ESL's?
Update: found some
Update… good news and bad news:
The good news is that I found and purchased four 50VA 230v/2x6v Farnell toroids from their U.S. distributor, Newmark. They sound fantastic driving my speakers and my amps seem OK with them so my problem is solved.
The bad new is that Newmark has discontinued stocking those trannys for sale in the U.S. and after filling my order they had only two left. I don't need any myself but but I'm looking for some for a friend's ESL project.
A company in the U.K. called “Airlink” has 50VA 230v/2x6v trannys at a great price (9 pounds) and they sell retail at their website but when I attempted to place an order, their automated service would not complete the order without me first typing in the shipping cost. I then received an automated email from Airlink stating they would get back to me shortly with the shipping cost and I could then complete the order. It’s been almost two weeks without a response so my search continues…
. . . 50VA 230v/2x6v Farnell toroids . . . that Newmark has discontinued stocking
FWIW, the US distributor is Newark, where Farnell is Newark's parent company, which stocks Multipcomp's transformers and drop ships to Newark's US customers for a $20 handling fee.
It is the single primary/single secondary unit that you must have ordered and that will no longer be stocked. Multicomp's single primary/dual secondary line is available, although the 50VA 230V/6V-6V units are not in stock, and have a predicted lead time of 4 months. Still, if enough people pool their money and place a consolidated order, Newark may be able to persuade Multicomp to run a batch sooner than that.
I bought the ones shown in the links below. I sure hope you're right about those trannys possibly being available again in a few months because the price was great and I couldn't be happier with their sound in my hybrids.
If anyone wants to go in for a group buy, count me in for another quad!
MULTICOMP|MCFG050/06|TOROIDAL TRANSFORMER VOUT: 6V | Newark.com
The Jazzman's Electrostatic Loudspeaker Blog
Okay, now go to that link, which is for the single primary/single secondary unit, which is no longer available. Now click on the [SHOW SUBSTITUTES] button at the bottom of the description. This will take you to the dual secondary version, which is the one that can be ordered.
It is not shown as being on back order, so when someone orders it, that is what will start the 85 day clock.
On the plus side, the minimum quantity is one, so a large quantity is not needed to start the clock. My point was that a large quantity might speed it up. It is also possible that the lead time is not accurate, and could be shorter if, for some other reason, a production run is made.
Hey David, that's great info.. thanks for that tip.
You know, I spent months designing and building my stats and I'll bet most others here spent at least a couple of months on their builds too.... so, it seems to me that waiting 85 days for trannys wouldn't be a big deal if the trannys are ordered at the start of a build. 😎
[/url]
Hey CharlieM, thanks for all the updates. What configuration are you using your transformers in (series...parallel...voltage ratio...)? Glad to hear it's working out so well for you.
Few
Few
Hi Few,
Long time no see, buddy. These trannys have dual windings on the 6v side and a single winding on the 230v side. I followed one of Calvin's threads and wired them up up backwards in tandem, 6v windings wired parallel facing the amp and 230v windings wired series facing the stators. The 230v side is center tapped out to the neutral side of the bias power supply for the diaphragm. OK, for a single tranny the ratio would be (230/6)= 38:1 so a tandem would be 2x38= 76:1 Calvin's thread indicates that losses would make the actual step up in praxis around 68:1.
My stat panels are 12X48 inches with 1/16 stator/diaphram spacing, which should be around 1nf of capacitance (?). Please note that I've got a 1ohm 10 watt wire-wound resistor in the hot lead between the amp and trannys.
I'm biamping with active x-over @ 380 hz and (2) 225w/channel Carver amps. I don't know that anyone has tried these trannys in ESL's so I was worried about shorting one out and smoking an amp but I've cranked up the volume momentarily to way past my pain threshold and nothing smoked. I don't have any measuring equipment, only my ears, but it sounds wonderful to me.
I can't figure out how to upload a wiring sketch here but as soon as I've posted this message I will add a wiring sketch on my blog page here:
CharlieM
I've tried a few off the shelve toroids with similar configuration that you have mentioned. However I found that the high frequencies from these trannys were dull. I didn't feel it at first, but when I compared the sound with my other speakers, it was very obvious. Don't you have that problem?
Wachara C.
Hi Few,
Likewise. I'm still around--sometimes lurking, sometimes chiming in with posts. The tone of some of the "repartee" here in diyaudio-land often puts me off a bit so I periodically consider signing off for good, but I can't seem to kick the habit of reading about speaker design.
Thanks for the info on your transformer set-up. Have you considered taking the measurement plunge? It seems to get easier and easier with free software and such, and you might be able to squeeze the last ounce of performance from your creations. They look great, by the way.
The ESL panels are really great for jazz, aren't they? I'll never forget the first time I heard John Coltrane's Giant Steps through my diy-ESLs. It felt more like a time machine than an audio reproduction system. Even with the flaws in the recording it was really memorable.
Thanks again for sharing your progress.
Few
