Anyone know any powerful power MOSFET?
"then how do think about the irf1404, powerful enough?"
For what? Its a low voltage switch.
If that's what you need then buy one.
If I was building a linear amplifier it would not be on my list as a possible output device.
What would you like to build?
The IRF1404 would be suitable for the original Zen design from Nelson Pass, but that's about it.
I noticed we use a lot of IRFP360 at work, our cost is only $1.15 each. These are in the larger TO247 package, easier to heatsink than the smaller TO220 package that the IRF1404 is in. A 250W amplifier could be made from a single pair of these. We also use the IFRP250 at $0.77 each, a pair of these could be run at 200W in class AB with a good sized heatsink.
The cost of the chassis, heatsink, and power supply tend to make the cost of the transistors not matter.
